ขายรถใหม่ BMW M5 (F10) 10.9M
  • 10095 Views
Offline nivit
  • 5
« on: 30 August 2016, 12:23:12 »
Brand BMW
Model M5
Generation M5 (F10)
Engine Competition Package 4.4 V8 (575 Hp) Automatic
Doors 4
Power 575 hp/6000-7000 rpm.
Maximum speed 250 km/h
Acceleration 0 - 100 km/h  4.3 sec
Fuel tank volume 80 l
Year of putting into production 2011 year
Coupe type Sedan
Seats 5
Length 4910 mm.
Width 1891 mm.
Height 1457 mm.
Wheelbase 2964 mm.
Front track 1627 mm.
Rear (Back) track 1582 mm.
Drag coefficient 0.33
Minimum volume of Luggage (trunk) 520
Position of engine Front, longitudinal
Engine displacement 4395 cm3
Torque 680 Nm/1500-5750 rpm.
 Fuel System Direct injection
Turbine Twin-power turbo
Position of cylinders V engine
Number of cylinders 8
Bore 89 mm.
Stroke 88.3 mm.
Compression ratio 10
Number of valves per cylinder 4
Engine oil capacity 8.4
Coolant 18.5
Fuel Type Petrol (Gasoline)
Wheel Drive Rear wheel drive
Number of Gears (automatic transmission) 7
Front suspension Double wishbone
Rear suspension Multi-link independent
Front brakes Ventilated discs
Rear brakes Ventilated discs
ABS
Steering type Steering rack
Minimum turning circle (turning diameter) 12.6 m
Fuel consumption (economy) - urban 13.9 l/100 km.
Fuel consumption (economy) - extra urban 7.6 l/100 km.
Fuel consumption (economy) - combined 9.9 l/100 km.
Emission standard EURO V
CO2 emissions 231 g/km
Kerb Weight 1870 kg.
Max. weight 2410 kg.
Max. roof load 100 kg.
Permitted trailer load with brakes (12%) 2000 kg.
Permitted trailer load without brakes 750 kg .
Permitted towbar download 90 kg.
Tire size 265/40 R19 102Y; 295/35 R19 104Y
Wheel rims size 9 J x 19; 10 J x 19
Contact:   085-6688-628 (น็อต)
Line ID: knot124
